Unread 03-27-2013, 04:08 PM   #1
Default WTT For 10+ Grand Sport Or Sale- '11 SS Highly Mod'd, 8.50 Cage, Chute, 5200 Miles
5200 Original Miles
Less than 300 on new motor.
Currently ranked #3 on stock displacement fastest list. Went 9.87 @ 136.5 with the stock bottom end, before that was pulled in favor of the forged combination.
2011 Camaro SS CGM w/ Silver Stripes
- Originally Manual 6-Speed
- Carfax is clean, never been in an accident
- 2SS / RS Packages
Powertrain
LRB Performance Built 417ci Motor (Less than 300 miles on build)
- Built to handle 20+ PSI / 1200+ HP
10.6:1 Compression Ratio
Callies Dragonslayer Crankshaft 4.000"
Manley 4.070" Bore Piston Set w/ Steel Rings
R&R Custom Billet Connecting Rods 6.125"
PRC Stage 3 CNC LS3 Cylinder Heads
Stainless Valves Int/Exh
PRC Dual Valvespring Kit w/ Titanium Retainers
LS3 Stock Intake Manifold w/ Vararam Air Intake
Comp 251/259 Camshaft 115LSA (3 Bolt Cam)
American Racing Headers 2" Primaries into custom 3.5" Collectors with 3x3" X-Pipe & ARH 2.5" Street Axle Back
Jet Hot Coated Matte Black on Headers
Melling Select Oil Pump
C5R Timing Chain Set
Taylor 409 Wire Set w/ NGK TR6 Spark Plugs
ARP Main Stud Kit
ARP L19 Head Stud Kit
Fuel System
Squash Dual Walbro 400 Double Pumper
FSP Custom Feed & Return Lines
Utilizes Stock Fuel Rail w/ Aeromotive A1000 Regulator; -8AN Feed, -6AN Return
ID-1000 Injector Set
Drivetrain
DSS 9" IRS Conversion Kit w/ 3.55 Gears & True-Trac Posi
Custom 4" Aluminum Driveshaft for 4L60E Trans (No parking brake cables because of shaft size)
ECS Built 4L60E Transmission; Includes 300M Input & Output Shafts, Rossler Trans Brake kit with Deep Pan, Custom Crossmember, 5-Pinion Planetary; All the works to handle the originally expected boost levels
Opti-Shift Transmission Control Module
E/S Poly Trans Mount
TCI SFI Flexplate
PATC Custom 3500 Stall Billet Torque Converter
Quicktime SFI Approved Bellhousing
Driveshaft Loop
Suspension
Pfadt First Gen Street Coilover Kit w/ Drag Springs
Pfadt Rear Drag Sway Bar
Pfadt Lower Control Arm Bushing Set (Rear-Poly)
Pfadt Subframe Bushing Set
Pfadt Adjustable Toe Rod Set
Pfadt Trailing Arm Set
Farks No-Hop Upper Control Arm Bushing Set
NO Front Sway Bar Included
Wheels/Tires (Less than 300 miles)
6x Weld RT-S 17" Rims (17x5, 17x8, 17x11)
M&H 28" Bias Play Skinnies for 17x5 Front Rims
M&H 325/45/17 Drag Radials for 17x11 Rear Rims
Sumitomo Tires for 17x8 Front Rims (For street driving without using the skinnies)
Chassis
Farks Custom 8-Point Rollcage good for 8.50 Certification (Not cert'd yet but will guarantee cert)
Farks Window Net Kit
Farks Custom Parachute Mount, includes Stroud 420 Parachute (Parachute mount is powder-coated Cyber Gray Metallic to match the vehicle)
Farks Custom Battery Cutoff Switch (Mounted in trunk, pull/push switch through fender, just needs to be wired to and from the battery/alternator)
Interior
Headliner has been cut for access around cage. The top dome light/console is not installed.
RCI 5-Point Seatbelt Harness w/ Cam Lock Drivers Side Only
Stock seatbelts remain for front passengers
All stock seats are installed. Some small interior panels are left off for the cage fitment.
Cage went through forward dash on both sides, but Farid made the A/C vents operable again.
Air Conditioning/Heat all still work perfect.
Innovative Motorsports MX-L Wideband Mounted off Rollcage
Stock 6L80E Shifter for use with the 4L60E
Misc.
Biondo Custom Line Lock Installed
MSD 2-Step Box
Has been owned by me personally since delivery at 35 miles. Professionally built. Modified by ECS technician's or FSP Rodney.
Car has dyno'd Naturally Aspirated 490rwhp on our Mustang Dyno through a 4L60E with the stock LS3 intake manifold.. it's just waiting for boost or nitrous to make that big number. Previously did dyno with a Novi 2200 at 16psi no meth at 710rwhp. Motor has less than 300 miles on it, about 15 1/4 mile passes. Car has gone a best of 1.39 60' on this same combination, not using the transbrake.
There are a few nicks/scratches on the paint. We will have all the decals professionally removed, car will be gone through by a professional detailer paid for by me once an agreement has been reached.
Looking for $58,000, will field best offers. Professionally built vehicle, low mileage. Will be looking to trade for a nice 2010+ Grand Sport, 6L80E Automatics only, rest of options are a moot point for me. Prefer near stock car.
PM me for List of Pictures!!!
In the pictures below, you will see a FAST 102mm intake, this is available for an additional $800 over purchase price agreement. You will also see some Nitrous Outlet (Plate & -6AN Feed line) accessories, I can make the nitrous kit whole (Spray up to 350RWHP shot) for an additional $2500 wired in and tuned. The Vararam is off in one of these pictures because it was during the FAST intake installation, but that is included.
Serious inquires please PM or email me (matt@floridaspeedandpower.com). There is NO NEED for me to sell the car, this is purely a business move to build another project vehicle for us.
HTML code is On
Page generated in 0.11382699 seconds with 10 queries
