Unread 10-31-2006, 02:19 AM   #1
Default FOB reprogramming
Found this little tidbit that might come in handy some day:
Transmitter Programming/Synchronization
Each transmitter has a unique Vehicle Access Code (VAC) that changes every 5 seconds. If a transmitter or receiver is replaced, each transmitter must be programmed to the vehicle's receiver. Entering a specific button sequence on the DIC, up to three transmitters can be programmed into the receiver. After programming the transmitters to the vehicle, the receiver will update this code every 5 seconds in order to match the code programmed in the transmitter.
The transmitter may not communicate or become out of synchronization with the receiver if any of the following situations occurs:
• The transmitter battery is disconnected.
• The vehicle battery is disconnected.
• The transmitter and the vehicle are separated for 2 weeks or more.
• The receiver is disconnected.
Perform the synchronizing procedure if the transmitter does not communicate or becomes out of synchronization with the receiver. If the transmitter and/or receiver are replaced, perform the following programming procedure:
Reprogramming
1. Turn the ignition to ON.
2. Turn the radio to OFF.
3. Press the RESET button in order to clear any IPC warning messages.
4. Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
5. Press and hold the RESET button for 3 seconds.
6. Press the OPTIONS button until FOB TRAINING message is displayed.
7. Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1 ST FOB will be displayed.
8. Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
The receiver will cancel the programming sequence if any of the following conditions occur:
• The program mode is exited through the DIe.
• The ignition is turned to OFF.
• The three transmitters have been programmed.
• The RFA system has been in the program mode for longer that 2 minutes and not transmitters have been learned.
Unread 08-09-2007, 12:12 PM   #2
sandman
sandman's Avatar
sandman is on a distinguished road
Reprogramming
Rich would this apply to a 1991?
sandman is offline   Reply With Quote
Unread 08-09-2007, 03:39 PM   #3
Sorry, but I have NO idea....
Unread 08-10-2007, 09:54 AM   #4
sandman
sandman's Avatar
No problem
SM
Page generated in 0.03860307 seconds with 10 queries
