Unread 01-22-2007, 01:10 AM   #1
1988-c4-phil
1988-c4-phil has disabled reputation
Default radio blues
1.
My 1988 C4 I just aquired had a 50 watt Sony aftermarket radio in it that did not work. I removed the radio and checked it out and found the fault was the radio. I purchased a 52 watt Sony so that i could use the same plug that was installed (supposedly professional). My question is why are there several in line power resistors? Do i need them? I noticed that after just a few minutes of the radio being on, the back of it got quite warm! is that normal?
My first thought is to bench test the radio on some other speakers i have hooked up to a spare battery and see if i still have the same heat problem.
I will attach a couple of pics to show the resistors in this thread.
2.
I have the annoying ~wheel rub~ sound that I belive is my rear end asking for lubrication.
I keep reading about AMSIOL, and GOLDMAX (I think), what is my best option to add? I am thinking of draining and replacing, and if I do what lubes come with posi-lube allready mixed.
sorry for re-hashing an old subject, but us newbies with short memories get confused real fast!!
thank you
Phil
1988-c4-phil is offline   Reply With Quote
Unread 01-22-2007, 01:14 AM   #2
1988-c4-phil
Unread 01-22-2007, 01:15 AM   #3
1988-c4-phil
Watts of my radio Classy General Corvette Discussions 4 12-30-2007 08:09 AM
Radio lockout recovery procedure Rich Z Maintenance, Mods, & Tips 0 04-10-2006 06:36 PM
Page generated in 0.03545189 seconds with 11 queries
