Unread 01-19-2024, 11:00 AM   #1
Default FS (For Sale) 1976 4-Speed Coupe
For sale - 1976 Corvette 4-speed - located in Central Florida
Below is a list of work that has been performed and some that still needs to be completed if desired.
  • Front suspension:
    • New upper and lower Moog ball joints
    • New upper and lower control arm bushings
    • New sway arm bushings
    • New Moog tie rods
    • New Moog idler arm
    • New poly bushings entire front end
    • New timken front bearings
    • New power steering hoses
    • Rebuilt power steering cylinder
    • Rebuilt steering box (Bair’s rebuild)
    • New shocks
    • New coil springs
  • Rear suspension:
    • Rebuilt rear trailing arms and new bushings
    • New half shafts with u-joints (Spicer brand)
    • New drive shaft u-joints
    • New differential front mount bracket bushing
    • New rear end crossmember bushing
    • New shocks
    • New spring liners installed in the rear spring
    • New strut rod bushings
    • New transmission mount
  • Brakes:
    • New front and rear stainless steel brake lines (master cylinder to calipers)
    • New brake calipers (front and rear)
    • New brake rotors (front and rear)
    • Rebuilt master cylinder
    • New parking brake hardware
  • Tires and rims
    • Front rims are 18” and tires are 255 40 18​​​​​
    • Rear rims are 18" and tires are 275 40 18
  • Interior:
    • Interior is 2 tone (smoke gray and black)
    • New smoke gray carpet
    • Sound deadener throughout interior
    • Interior is in very good shape
    • Power windows - both work
    • Car does not leak in the rain (I’ll be honest, I don’t test this often)
  • Transmission:
    • M21 muncie four speed
    • T​​ransmission was rebuilt using 5speeds.com rebuild kit
    • Hurst shifter, recently rebuilt using 5speeds.com rebuild kit
    • Lakewood scatter proof bellhousing
    • New clutch and pressure plate
    • Clutch - hydraulic
  • Engine
    • New aluminum radiator (not a DeWitts)
    • New tach board and tach filter
    • Edelbrock carburetor
    • Metal fuel line from fuel pump to carb
    • Edelbrock RPM manifold
    • New distributor and spark plug wires
    • Headman headers
    • New power master starter
    • Unknown if any other engine work has been performed
  • Miscellaneous
    • New rear tail and back-up light lens
    • 69-75 style steering column (non tilt/telescoping type)
  • Frame:
    • #1 mounts are good
    • #2 mounts are good
    • #3 mounts are good
    • #4 mounts are good
    • New body mount bushings all around
    • Trailing arm pockets are good (no rust)
    • Rocker channels are good
    • Visible windshield frame (i.e. what can be seen when interior trim is removed) is good (no rust)
  • Body/paint:
    • Paint looks nice at 10 feet and 10 mph - daily driver quality
  • Miscellaneous continued:
    • Car was born dark brown with saddle interior (now white with black/gray interior)
    • Windshield wipers work
    • Headlights work
    • Engine pad stamp vin number matches pillar post vin number
  • The Bad:
    • Speedometer does not work - I just can’t figure this one out yet
    • Clock does not work
    • Original radio does not work
    • Needs new antenna
    • I have found some fiberglass repairs
    • Radiator core support has rust in the usual location (very bottom) - I have a spare that is in much better shape that I will include.
    • Fan shroud has a few cracks that have been repaired
    • Car had AC, but that is long since gone
Probably more stuff, I just can't remember. Asking $9,800 OBO with the 18 inch rims and tires. If you prefer, I have a set of rallies with caps and trim rings (will need tires), asking $8,800 OBO with the rallies instead of the 18 inch rims.
More pictures in my 1976 photo album.
HTML code is On
[C5] FS (For Sale) FS 2002BLK-BLK Coupe Six Speed Miles 82,650 RSS Feed RSS Classifieds 0 04-16-2022 11:29 PM
[VIDEO] Hungarian Speed Shop Mates a 1976 Corvette Body on a C6 Chassis for Stunning RSS Feed Corvette News Feeds 0 03-31-2021 01:39 PM
[C5] Supercharged 1999 C5 Coupe, 6 Speed, 51,000 miles RSS Feed RSS Classifieds 0 01-14-2016 07:54 PM
[C6] FS: 2011 Supersonic Blue 3LT Coupe 6 Speed (South FLorida) RSS Feed RSS Classifieds 0 03-07-2015 10:17 AM
2009 Barrett-Jackson Corvette Auction Preview RSS Feed Corvette News Feeds 0 01-10-2009 02:53 AM
Page generated in 0.05540109 seconds with 10 queries
