Unread 07-11-2011, 07:38 AM   #1
navy2kcoupe
!ereH nI depparT m'I pleH
navy2kcoupe's Avatar
Default Belt Tensioner
Guys and Gals, if your belt tensioner looks like the left one in the following picture,
my advice to you is to change it quickly. My 2000 Coupe threw the belt off, so I bought
a new one. The old one still looked good, but I didn't want to trust it. Then the new belt
got thrown off, and I started to look at other things. The tensioner on the left is what
I finally decided was the culprit, and changed it out. 20 minutes is all it took, and the
belt hasn't been thrown off since. I've looked at about 10 or 12 LS1's since the
problem and none of them showed the same wear as my old one. The tension on the old one
seemed to be as tight as on the new one, so I don't think it was losing tension
and allowing the belt to come off. When I was looking at it, with the engine running,
the belt was moving towards the front of the water pump pulley. I expect that at some
point, it got too far forward and got thrown off. With the new tensioner on the engine,
the belt rides true and in the center of the water pump pulley. I'm the 3rd owner
and don't know if this is an original tensioner or not, but with only 45K on it I suspect
that it is.
Andy
Unread 07-11-2011, 10:52 AM   #2
Yeah, you can definitely see that the old one is bent. Hopefully you didn't get stranded somewhere when the belts got thrown.
Unread 07-11-2011, 01:15 PM   #3
navy2kcoupe
Threw the old belt in the garage. Bought a new belt and installed it, and 2 days later
THAT belt got thrown off too......in the garage again! Pretty lucky I guess.....
Andy
Unread 07-11-2011, 06:03 PM   #4
Andy
Yeah... Much better than being in the middle of Death Valley or something when it happened.....
Unread 07-11-2011, 07:09 PM   #5
navy2kcoupe
IMMEDIATELY after the first thrown belt, and right up to this minute, I keep the wrench for
the tensioner in one of the cubby holes in the back! Maybe it'll come in handy to help
somebody else in the future. The old belt is back there too........just in case...
Andy
Mechanics Tip - Belt Tensioner XQIZT General BS forum 2 05-30-2010 07:10 PM
C5 Corvette Belt Install - No Idle(r) Matter RSS Feed Tech and How-To Articles 0 05-18-2010 03:42 AM
C5 Corvette Belt Install - No Idle(r) Matter RSS Feed Tech and How-To Articles 0 04-19-2010 04:30 PM
Florida ranks top in national safety belt usage RSS Feed Florida News Feeds 0 10-22-2009 01:35 PM
CHARGE SYSTEM FAULT Rich Z Maintenance, Mods, & Tips 50 06-05-2006 03:39 PM
Page generated in 0.05534792 seconds with 10 queries
