Some fuel and vacuum parts needed
Staff member
Hey Chris,
I'm looking for a few parts and maybe you can help me out.
First up is that I want to replace my fuel pressure regulator. Not sure of the model number, but it's an Aeromotive unit:
I've got a -8AN hose going into a -10AN fitting on the FPR on one side, with the other side plugged with a -10AN plug. Return is a -6AN line. I would like to keep my plumbing unaltered, if possible. And I would like to keep it mounted where the old one is located, so the mounting bracket could be an issue.
Also looking for a vacuum manifold block such as this -> http://www.amazon.com/gp/product/B003ZX2SUO/ref=ox_sc_act_image_2?ie=UTF8&m=A2QFNSS8NFRXPI
I'm not sure what you may sell in the way of vacuum fittings and adapters but likely I will need some (type unknown at this point) for me to install this thing.
Can you help me with these, please?
Thanks.
Rich,
I believe the regulator you have is the Aeromotive 13101: http://aeromotiveinc.com/products-p...lators/13101-a1000-injected-bypass-regulator/ To be 100% sure the bracket will be the same it would seem the Aeromotive regulator is the best choice, which I can supply. A rebuild kit is also available for this regulator; Aeromotive 13001.
Another choice: I stock and recommend Fuelab regulators; I believe the Fuelab 51501 regulator will work in your application, and is available in blue: https://partsforspeed.com/home/air-...fi-fuel-pressure-regulator-10an-6an-blue.html
I do not have a supplier for the manifold vacuum block, I checked with my warehouses and it is not available. Similar blocks are available from various retailers, these blocks appear to be common in the import / turbo world.
I can supply almost any performance plumbing brand, please email a list of your plumbing needs and I will check price and availability.
Thanks!
Chris
Chris, thanks. How much is the rebuild kit for that Aeromotive regulator?
I did find a vacuum block on Ebay, so I'll just go ahead and get one of them that way.
Thanks!
