Unread 04-15-2009, 05:51 PM   #1
grumpyvette
retired mech engineer
grumpyvette's Avatar
grumpyvette has disabled reputation
Default block decked .010 how much diferance in compression ratio
OK youve decked the block .010 durring the block machining process , how did that change the compression?
if you decked the block .010 youve effectively moved the piston .010 closer to the cylinder heads unless the head gasket is selected to be .010 thicker to compensate
I don,t know the bore dia. but lets assume in a calculation its 4" bore
cutting a deck on a block and not compensating with a thicker head gasket on that 4" bore had about a 2 cc reduction in the total area over the piston being compressed, into the combustion chamber above it, simply because the area of the bore times the depth of the cylinder results in that volume
formula
bore radias sq x 3.147 x .010 x 16.39(changes cubic inches to CCs)
(referance you need TO COMPLETE THE CALCS)
http://www.hotrod.com/techarticles/e...tio/index.html
http://www.circletrack.com/techartic...ion/index.html
http://forum.grumpysperformance.com/...hp?f=86&t=1330
http://forum.grumpysperformance.com/...php?f=52&t=727
http://forum.grumpysperformance.com/...php?f=53&t=726
grumpyvette is offline   Reply With Quote
Unread 04-15-2009, 09:30 PM   #2
Bradzvette
PW Pimp, keeper O' 'da thread
Bradzvette is on a distinguished road
Is this a test? LOL
I'm guessing you will increase by .4 or so?
Bradzvette is offline   Reply With Quote
Page generated in 0.88001490 seconds with 9 queries
