Unread 07-13-2006, 08:10 PM   #1
cdwoodring98
cdwoodring98 has disabled reputation
Arrow Corrosion Repair
I have a 1976 with some corrosion issues on the rh and lh floor pans...seat pans are ok, but have a leak coming in what looks like the wiper compartment...a bit of rust through on the passenger side, but it does not appear to be affecting the entire pan...i would like to repair the pan vice replace....any ideas as to repair or recommendations as well as how to plug the leak....appreciate any tips...i am in Tampa, so if you know of any place that might do the metalwork would appreciate a heads up....
cdwoodring98 is offline   Reply With Quote
Unread 08-02-2006, 09:49 AM   #2
Melsy
Melsy has disabled reputation
The C3 has very common leakage issues in the wiper valley. There was a TSB back then about sealing the wiper valley with undercoating spray. Many of my C3's had this done by the dealer. I'm sure there are better alternatives today. Also check the "doughnut/gasket" where the steering column comes through the firewall. Poor fit or totally left out during production was not uncommon. Once you get this done, then you can attack the corrosion.
Melsy is offline   Reply With Quote
Unread 08-02-2006, 09:51 AM   #3
Melsy
One other common area of leakage is around the outside air vent on the passenger side. The gasket tends to fail with age, not to mention the vacuum solenoid does not close the door fully. Very crappy linkage. Hope these cobweb memories help.
Unread 08-03-2006, 10:41 PM   #4
TwistedFun
TwistedFun's Avatar
TwistedFun has disabled reputation
my 75 had the same leak. the undercoating did not work. i had to scrape it all off and use a body seam sealer that i got from an aoutomotive paint supply store. it worked well for me.
Striving to be the person my dog thinks I am!
TwistedFun is offline   Reply With Quote
Page generated in 0.12151098 seconds with 9 queries
