Originally Posted by Pseudomind
What did the Black Corvette have going for it? I am thinking it was not quite stock?
The specs are below. You can change the best E.T. to 10.06 (done last week sometime) and of course you've seen the video of the 10.16.
It was featured in Vette Magazine. Here is a link to the story and pictures.
http://www.vetteweb.com/features/vemp_0601_leake/
SPEC SHEET
Car: '02 Corvette Z06
Owner: Mike Leake
Block: GM C5-R racing aluminum
Displacement: 427 cubic inches (7.0 liters)
Compression ratio: 8.5:1
Heads: AFR 225 Mongoose (72cc chambers)
Valves: Manley stainless 2.02-in/1.60-in
Camshaft: COMP hydraulic roller
Rockers arms: COMP 1.6 ratio
Pistons: Wiseco forged-aluminum
Crankshaft: Lunati forged-steel
Rods: Lunati forged-aluminum
Intake manifold: Stock LS6
Fuel injectors: 72-lb low-impedance
Fuel pump: Lingenfelter/SX Performance high-pressure fuel pump, 80 gph
Ignition: Stock
Engine management: FAST/DFI (ACCEL)
Power adder: ATI ProCharger F-1C
Maximum boost: 36 psi
Exhaust system: Kooks 17/8-in long-tube headers; Stainless Works 3-inch exhaust system
Transmission: Stock T56 six-speed, rebuilt by Rockland Standard
Clutch: SPEC Stage 5
Driveshaft: Hardened main output shaft
Front suspension: Stock with HAL QA1 adjustable shocks
Rear suspension: Stock with HAL QA1 adjustable shocks
Rear end: Stock with hardened halfshafts, DTE trans brace
Front brakes: Stock with high-performance pads
Rear brakes: Stock with high-performance pads
Wheels: CCW 16-inch "drag package"
Front tires: Drag Skinnies
Rear tires: Hoosier 28x12x16
Fuel octane: 100 (minimum)
Weight: Approx. 3,200 lbs.
Best e.t./mph: 10.2 seconds @ 140.9 mph
Best 60-foot time: 1.59 seconds
Current mileage: 14,300
Miles driven weekly: Approx. 100 (during good weather)
