Unread 04-24-2008, 11:36 AM   #1
Odigital
Odigital's Avatar
Odigital has disabled reputation
Default 84 C4 Headlight Motor Problems
Well,
here is my first posting for help. My passenger headlight motor will not operate. At first I thought it was the motor. So I have replaced it with a new motor. Then it work sometimes and when it did not I would wiggle the plug and will operate. Now Im not getting any movement. Thinking that it was an issue with the female plug on the car I splice the wires and connected them directly to each other without the plug. Still nothing!?. I have been to other forums and they talk about an, actuator a relay and some other issue but I want to stop guessing and see if any C4 out there has had this issue and has fixed it. Any suggestions?
Odigital is offline   Reply With Quote
Unread 04-24-2008, 02:05 PM   #2
shakedown067
Sinister C4
shakedown067's Avatar
shakedown067 is on a distinguished road
I've heard the pre 86's are trickier than the rest. I'd give John over at AutoXTC a call (727-556-0335). He know's a crap load about the C4. I'm pretty sure you've already narrowed it down to the relay though.
shakedown067 is offline   Reply With Quote
Unread 04-24-2008, 07:53 PM   #3
Odigital
Odigital's Avatar
Default Thanks
thank you shakedown will try to contact them for help
Unread 04-25-2008, 05:38 AM   #4
Shadow
Shadow's Avatar
Shadow will become famous soon enough
John definately knows his stuff
Noting from your info that yuo're in Tampa, you might want to check also with Andreh at Insty Lube on North Dale Mabry:
Insty Tune & Lube - instytuneandlube.com
14783 N Dale Mabry Hwy, Tampa - (813) 960-3908
Total vette headOwns and works on them daily.
If you're around on Saturday afternoons, a good sized group of us meet up there from about 5 or so until 7:30-8 pm depending?
We come and go as we like and it's on the calendar as the "informal car show."
Bring the car up and he'll take a loiok at it
I won't be there this saturday, but tell him Gordon told you to talk to him.
He'll treat you well
Shadow is offline   Reply With Quote
Unread 04-25-2008, 07:36 AM   #5
Odigital
Odigital's Avatar
Default Thanks
Thanks Shadow (Gordon). I went to Instylube last saturday for my first time. Like yourself I will not be able to make this saturday. Ill will try to make it next saturday and see if I can get some help. Thank you guys for your replies. You guys have been helpful
Unread 04-25-2008, 01:50 PM   #6
Shadow
Shadow's Avatar
Anytime
**** C5 Headlight Gear replacement*** pewter99 Tech and How-To Articles 6 04-02-2009 01:40 PM
Headlight cracks. LS2POWA Maintenance, Mods, & Tips 7 04-16-2008 02:51 PM
95 Headlight Problem Anthony Caliendo Maintenance, Mods, & Tips 4 12-19-2007 10:47 AM
Cracked Headlight - 2007 C6 C6 Corvette - SRQ Maintenance, Mods, & Tips 2 08-05-2007 12:48 PM
C5 headlight gear replacement pewter99 Maintenance, Mods, & Tips 20 07-02-2006 12:07 PM
Page generated in 0.05185699 seconds with 11 queries
