Unread 02-06-2010, 09:39 AM   #1
Bob K
Deceased
Bob K has disabled reputation
Default Looking For Advice
I race a stock C5, A4. I tune it myself but I have never started at scratch and gone completely through it all. My car runs so consistent I am reluctant to make too many changes.
I have installed a Blackwing and 3:42 gears. I have adjusted the shift points and disabled Torque Mamagement. I have adjusted the injector flow rate to get my fuel trims zeroed out. I know that's a shortcut but it works.
I have scanned this car many times at the strip and the timing bothers me. But, like I said the car is consistent. At the initial hit of the throttle the timing drops to 2 deg total and then immediately picks back up. I don't have a clue what is causing this because I have triple checked everything. Should I add timing or leave it alone?
Bob K is offline   Reply With Quote
Unread 02-07-2010, 10:42 AM   #2
RevXtreme 1
www.revxtreme.com
RevXtreme 1's Avatar
RevXtreme 1 has disabled reputation
de-sensetize the knock sensors a bit to see if that eliminates it. Also, copy & paste the high octaine tables to the low octaine if you always use 93 so there is no switching between them to keep consistant.
Tech Support for most anything.
RevXtreme 1 is offline   Reply With Quote
Unread 02-07-2010, 10:49 AM   #3
Bob K
Deceased
Thanks Tracy. The low octane table already matches the high octane. How do I de-sensitive the sensors?
Page generated in 0.06011105 seconds with 10 queries
