Unread 12-31-2014, 12:10 AM   #1
presidential_detail
CQuartz FINEST Installer
presidential_detail's Avatar
presidential_detail has disabled reputation
Default 2015 C7 Z06 NEW CAR PREP - CQuartz Finest - Presidential Automotive Detailing - FL
I was recently contacted to perform a new car prep and Cquartz Finest application on this recently aquired 2015 Corvette Z06. We also performed a wheels-off service which includes removing each wheel to be hand polished and protected with Cquartz Finest inside and out. The calipers were also hand polished and coated to complete the package.
First off, WOW, what a beautiful machine! Not even two weeks into its life, its about to look even better than it came from the factory!
Wheels
As you can see, the owner has been enjoying it already.
Iron-X was used on the wheels to remove any embedded brake dust and road debris.
Initial wheel cleaning complete.
The rest of the car was cleaned using Optimum No Rinse, then every panel was clayed to ensure there were no contaminants embedded into the paint finish. Sorry, I forgot to take a photo of this step.
Once the car was cleaned, each wheel was removed to be hand polished in preparation to be coated with Cquartz Finest Ceramic Coating.
This is also the perfect time to treat the undercarriage, all plastic was treat with CarPro DLUX.
Each caliper was then hand polished and coated with Cquartz Finest, which has been tested to easily withstand temperatures up to and over 800F. This makes it a great option to help protect the finish on the calipers with normal street use.
Each wheel was hand polished inside and out to bring out a deep shine, then coated with Cquartz Finest for complete protection. Applying Cquartz Finest to the wheels helps reduce brake dust build up and makes future cleaning much easier for the client.
After Polishing.
Wheels are now fully polished and protected.
Paint Correction
With the wheels out of the way, I was able to turn my full attention to the paint finish. With the car only being a couple weeks old, it did not require a lot of correction, but there were some blemished in the paint that could still be removed. The light polishing will also bring up the gloss level from the factory finish before applying the Cquartz coating.
Here is an example of some of the defects that were found.
Now removed.
Some blemishes were also found in the roof panel.
Now removed.
Visit Our Site - Presidential Automotive Detailing
Authorized CQuartz FINEST Installer
presidential_detail is offline   Reply With Quote
Unread 12-31-2014, 12:11 AM   #2
presidential_detail
Before.
After.
Even though the car was brand new, there were already some etchings from bird droppings. Bird droppings, love bugs and hard water are some of the worst possible things for your paint finish. They should be removed immediately, as they can cause permanent damage to very quickly. Luckily, we caught this on in time and everything was able to be removed with a a little heavier cut. Sorry, forgot to take a photo in the same lighting, full shots in the sun will follow!
More blemishes found on the rear wing.
Now removed.
This spot was a bit odd to me, its possible it could be left over from the factory or caused during transport.
A closer look.
Now removed.
This spot appears to be from hard water resting for a long period of time, it was later removed by hand since a machine polisher cannot reach into this area.
The sun just happened to be peaking through at just the right angle for me to capture the true color of this beautiful machine before pulling it outside.
CQuartz FINEST Ceramic Paint Coating
The sun was dropping fast, so I decided to take my final photos after applying just a single layer of Cquartz Finest. Yes, this finish will still become deeper and achieve more gloss after 2 additional coats on top of this!
Unread 12-31-2014, 12:11 AM   #3
presidential_detail
To finish things off, the owner installed this incredible piece of artwork to the underside of the hood. Some amazing airbrush work went into this hood liner!
Unread 01-01-2015, 10:06 PM   #4
mrr23
The Alignment Guy
mrr23's Avatar
Name : Robert J Hinton
mrr23 is on a distinguished road
really nice work
the alignment guy
mrr23 is offline   Reply With Quote
Unread 01-02-2015, 10:40 AM   #5
presidential_detail
Thank you, It was a fun car to work on!
Unread 01-07-2015, 07:37 AM   #6
THOR
THOR's Avatar
THOR will become famous soon enough
Your craftsmanship is stellar!!!! Thanks for sharing. How long did this detail take?
THOR is offline   Reply With Quote
Unread 01-07-2015, 07:10 PM   #7
presidential_detail
Thank you Thor! If I remember correctly, I have about 15 hours into it over 1.5 days.
Unread 01-07-2015, 08:19 PM   #8
Man, I hate to think about all those new, previously unused, muscles that I would discover after a stint like that......
Unread 01-08-2015, 10:20 PM   #9
presidential_detail
Hahaha!
Unread 01-11-2015, 01:00 PM   #10
Kap142
Kap142's Avatar
Kap142 is on a distinguished road
Cost and time involved in doing correction and polishing on a C5 Z06. Basically what you did with the C7?
Ken
Kap142 is offline   Reply With Quote
Tags
cquartz finest, cquartz florida, presidential detailing, tampa detailing
C6 Z06 - Maximum Acceleration RSS Feed Tech and How-To Articles 0 02-07-2008 01:01 PM
Two Unique Corvettes to Pace the 2008 Indianapolis 500 RSS Feed Corvette News Feeds 0 12-30-2007 02:13 PM
Two Unique Corvettes to Pace the 2008 Indianapolis 500 RSS Feed Corvette News Feeds 0 12-28-2007 03:27 AM
C5Z vs. C6Z Zach Z06Fever! 4 05-14-2006 08:27 PM
Page generated in 0.43627191 seconds with 10 queries
