Active Handling Issue
C5Rick
Leaving for work this morning and the display read "Active Handling Warming"
I turned it off and on, but still there. I got about 1/2 mile further and car went into "Reduce Power" and I barely made it home. Any ideas.
Someone suggested I clear all my codes and so I did since I don't know any better. Car started right up and down the road it went with no problems. Now I'll have to take the rest of the day off and throughly check the car and make sure no more lights come on.
On a side note, Tim I finally got all that Tranny Fluid off my windshield and hood. I thought it would give me some extra gloss for Joey D's, but you got the Gold :lmao:
Had this warning on mine. A known issue. It occurs on a cold car when you turn hard and accelerate moderately. Usually clears itself as the active handling recalibrates. Maybe your turning it on and off added another variable which caused the reduced power.
Also, there were some issues caused by corrosion inside the hub sensor connections. If it persists, you might try cleaning the connections and adding some silicone dielectric grease to seal the connectors. If I remember correctly, there is a short cable on the front- clean the connectors at both ends. Rears have only 1 connector each side.
I know the white flash has a red tint to her:lmao: BTW you could have shakin up that car alittle when U had to made a exit stage right turn :rofl1: Ice Ice Baby:crazy03:
That's what I'm thinkin ...
I'll have to send Tim a bill for this one. I found another Coke this morning
I believe I'll send the cleaning bill from Sunday + 4 Microfibers + 1 bottle of Detail Spray used in Arcadia to Rickey Joe & Jake.
