Here are the codes I recorded:
10PCM, no codes
28TCS, no codes
40BCM, 1 code B0432H
58SDM, no codes
60IPC, no codes
80RAD, no codes
99HVAC, no codes
AO-LDCM, 3 codes B2284H, B2282H, U1064H
AI-RDCM, 4 codes B2203H U1064H B2283H B2285H
A6-SCM, 1 code U1160H
BORFA, 3 codes U1000H U1255H U1064H
Here is a suggestion I received from another individual.
When the dual climate goes out of sync, there is an easy procedure that works most of the time. Disconnect battery, reconnect battery. turn on ignition but don't start, turn both knobs full right (hot), then full left(cold). turn on engine and should be in sync. Unless there is a defective actuator.
Lee C from Tallahassee, Thanks for the help.
[/QUOTE]
No,I think you have different problems than a actuator!!:shrug01:
But the very first thing I do with electrical problems is Clean and Inspect All Grounding points!:thumbsup::thumbsup::thumbsup:Bad Grounds make electronics do weird SH*T!
Clean and Inspect All Ground points,Be sure to take apart the gang plugs by the Lt and Rt hood henge!:thumbsup::thumbsup:
Document ID# 666311
2001 Chevrolet/Geo Corvette
Diagnostic System Check - HVAC Systems - Automatic
Test Description
The number(s) below refer to the step number(s) on the diagnostic table.
Lack of communication may be due to a partial malfunction of the class 2 serial data circuit or due to a total malfunction of the class 2 serial data circuit. The specified procedure will determine the particular condition.
Determine if the HVAC Control Module, Body Control Module or Powertrain Control Module have set DTC's which may affect HVAC operation are present.
The presence of DTCs which begin with "U" indicate some other module is not communicating. The specified procedure will compile all the available information before tests are performed.
Answer Yes if the first 3 characters of the DTC name begins with B10; regardless of the last 2 characters.
Step
Action
Yes
No
Did you review A Diagnostic Starting Point - Heating, Ventilation and Air Conditioning?
Go to Step 2
Go to Diagnostic Starting Point - Heating, Ventilation and Air Conditioning in Heating, Ventilation and Air Conditioning
2
Install a scan tool.
Does the scan tool power up?
Go to Step 3
Go to Scan Tool Does Not Power Up in Data Link Communications
3
Turn ON the ignition, with the engine OFF.
Attempt to establish communication with the following control modules:
HVAC Control Module
Body Control Module
Does the scan tool communicate with the control modules?
Go to Step 4
Go to Scan Tool Does Not Communicate with Class 2 Device in Data Link Communications
4
Select the display DTCs function on the scan tool for the following modules:
HVAC Control Module
Body Control Module
Does the scan tool display any DTCs?
Go to Step 5
Go to Symptoms - HVAC Systems - Automatic
5
Does the scan tool display any DTCs which begin with a "U"?
Go to Step 6
6
Does the scan tool display DTC B10XX?
Go to Diagnostic Trouble Code (DTC) List in Body Control Systems
Go to Step 7
7
Does the scan tool display any DTCs which begin with a B that are associated with the charging system?
Go to Diagnostic Trouble Code (DTC) List in Engine Electrical
Go to Step 8
8
Does the scan tool display any DTCs that are associated with the HVAC system?
Go to Diagnostic Trouble Code (DTC) List in Engine Controls - 5.7L
:thumbsup:
