Ragg Topp...you can purchase a combo pkg from Eckler's with both cleaner and protector most vette owners swear by this product.:yesnod:
There is a thread around somewhere talking about problems with using the conditioner/sealer. It seems that a few people were not letting their top completely dry before applying the sealer. Sealing in moisture, which leads to fungal growth, and areas of fabric decay. Remember... If you are going to use a sealer on your top, after you wash it, use a "Shop Vac" to extract most of the water, then let it dry overnight in the garage then out in the direct sun for at least an hour. Just make sure that the top is completely DRY. Then apply the sealer.
:iagree:There is a thread around somewhere talking about problems with using the conditioner/sealer. It seems that a few people were not letting their top completely dry before applying the sealer. Sealing in moisture, which leads to fungal growth, and areas of fabric decay. Remember... If you are going to use a sealer on your top, after you wash it, use a "Shop Vac" to extract most of the water, then let it dry overnight in the garage then out in the direct sun for at least an hour. Just make sure that the top is completely DRY. Then apply the sealer.
