FS - C3 Camber Rods
LEJ ZO6
LEJ ZO6
For Sale – Rear Camber Adjusting Struts & Bracket
These struts eliminate the eccentric cam adjustment used on the stock C3. The strut rods are swaged steel and rod ends replace the stock rubber bushings and eliminate any unwanted movement. After adjustment is complete the lock nuts are tightened and your camber settings stay in place. The center bracket is modified using square plates in place of the stock cam adjusters so nothing will slip.
If you autocross, road race or do track days with your 63-82 and still have the stock rear camber adjusters you need these!
I’d like to get $100 plus $15 for priority shipping.
Lloyd Johnson
Tamps, Fl.
