Goldies operation:
RevXtreme 1
www.revxtreme.com
Goldie had an upper-end oiling issue after we put in the new roller cam & lifters so we used the boroscope to look dow into the cam journals and we see the rear most is not seated in all the way...in fact it is almost a 1/8" out so that looks like the culprit:
We then pulled the motor (we hand only done a in-car cam swap to begin with due to lobes starting to wear on the flat-tappet cam):
so we could inspect all oil galleys & passages for obstructions (Grump, take a look at this)
and here is a pic of the rear cam bearing before removal:
Not good looking and you can see a good part of the oil hole is blocked from it not being seated properly. Most likley from the machine shop that did the original machining on the block since the build is first class. Whoever rebuilt this motor before (and it still looks like new inside) had done a fabulous job. Note the pic below of the rear oil groove with the bearing removed. You can see how the bearing not seated all the way was obstructing it:
Here are some shots of the quality of the build before Ken got it. Cyl walls show no wear, but nice even glaze from the rings seateing properly:
Here are a series of pics of the balacing job done.....note drill relief holes in the piston bottoms & the chamfer's where material was removed on the rod caps. This motor was built right:
Motor is going back together now (yes we work 24/7....or so it seems) and hope to drop in back in Monday with Tue as a goal to deliver it.
:dancer01:
Here are the intake ports on Goldies heads....the original builder did a great job on the porting:
But the intake manifold is bone stock, so I assume it had a port matched alum on it at first:
Note the gaskets we had matched to the heads during the cam swap, well we decided to match the intake to it while it is apart as a gift for being w/out the car this long. :thumbsup:
Nice write up and the pictures were awesome. Posts like this one are just one of the reasons that I like this site. Knowing the car being worked on (and the owners) just makes it that much more interesting! Thanks to the people at RevXtreme for the good info, and to Ken and Carrie for providing the "donor car":eek:
Andy :wavey:
Andy :wavey:
Ken & Carries car is awesome.....so we are going the "extra mile" to get it perfect.:thumbsup:
Dropping the motor in tomorrow morning, then on the dyno if no delays. We'll get it up to you guy's by Thursday now if all goes smooth, and it's looking good. We put the same coated bearings in that we do in all our race big blocks just for insurance.:thumbsup:
Ken, watch out for the right foot when you get "Goldie" back ! :yesnod:
Don't want any of those little "thingies" that you hafta sign and that take money out of your pocket! (and I DO NOT mean the bill!)
The motor looks AWESOME ! :thumbsup:
Andy :wavey:
Looking good Ken. I know you miss Goldie really BAD.
Tracy, I'm just curious; why is Ken's restoration taking so long? I don't understand why it takes several weeks to get Goldie up and running. Again, just curious and no criticism intended.
We had to disassemble the entire engine to make sure there were no other obstructions even though the cam bearing was obvious. We also are doing it for a bare minimum cost to Ken so we have put the reg rate pay jobs ahead of it to do so. We also originally did the cam swap in car, and to find & correct the problem (that appears to have caused the first original failure) we had to pull the motor (not easy in a BB C3!) to do so. And while it was out & apart we decided to port the intake to match the heads & refinish all his engine parts, exhaust manifolds, water pump, etc. since he shows the car.:thumbsup:
S-E-R-V-I-C-E ! :thumbsup::thumbsup::thumbsup:
Awesome !!!!
It looks like the waiting will be well worth it Ken ! :yesnod:
Andy :wavey:
HOLY CRAP....that motor is looking awsome. ORANGE !
I expected to have it all finished yesterday, only need to fill fluids & button up the last bits but I had to go to Port Charlotte today to tune a built Audi S4 V8.....and man the Relentless RPM shop is awesome. AWD dyno....spread the word to the guys that need one, very professional team there. Ran into Corey (LS2POWA) there as well.
I urge all that can to attened the dyno day tomorrow to at the very least meet & greet. Some nice rides there. :thumbsup:
Of course you were in Port Charlotte,I was in Your area yesterday and you were in mine:lmao::lmao::lmao: Sorry I missed you Tracey.
That was nice for you to say that about Relentless,They are pretty cool people there.
So what's the latest on Goldie?????? Is she up and running with her love sick owner smiling at the wheel??? :shrug01:
