Grip On Anti Slip Solution
Safety Seal
Official Sponsor
Grip On is one of the most important products on the market.
Business Owners and Private Individuals are becoming more concerned with keeping their property safe from accidental slip and falls.
This is where we can help!!
Grip On has been applied to hundreds of Hotels, Restaurants, Nursing Homes, Hospitals, and Residential Units. Some of our high end clientele included McDonalds, Burger King, Marriot Hotels, Hilton Hotels, Trumps Properties, G.L. Homes, and the list goes on and on.
A floor or surface NOT treated with Grip On could potentially cost you thousands of dollars should an accident occur. Peace of Mind is Priceless!!
Some of the key uses for Grip On are treating any type of polished or glazed ceramic tile, granite, marble, brick, and concrete. Bath tubs, restrooms, and kitchens are the strongest areas that we serve.
This anti-slip solution will not damage the surface you are treating nor will
it dull the shine on polished materials.
Also, please keep in mind that your normal walkways can benefit from this product as well whether in your home or outside on the patio or driveway. Even around the pool is a fantastic use for this product.
A one time application of Grip On will last 1 year in high traffic areas and 2 years in bath tubs and showers. Guaranteed!!
And don’t worry it’s as simple as washing your floor to apply. There is no mixing at all! Just spread it on, brush it in, let it sit for 15-20 min, and rinse it clean. It’s that EASY!
Also, if you are not comfortable with applying Grip On yourself we do have a full service installation team that can come to your work or home and take care of the surface treatment for you.
If interested in ordering or scheduling an install please call Jason Knox
at 877-474-7661 or email jknox@safetysealproducts.com
I'm especially interested in the Grip on..does it work on other surfaces just as well, such as wood (decks), Congoleum (tile) or Lanoleum and Pergo type floors.
Oh, and is it abrasive?
~Ray
Grip On is NOT abrasive and will not etch your floors like some other anti-slip products. Unfortunately it does not work on real wood. However it works on some stuff like glass and fiberglass but they are hit or miss sometimes b/c of the different compositions and the other issue is the length of time it is effective on those surfaces.
As far as Congoleum and Lanoleum it actually will work great on those surfaces BUT usually after being waxed, buffed, or heavily cleaned you will have to re-apply. If this is the case we can give you some special pricing to help you out.
And Pergo is a synthetic which has no pores to penetrate into the surface and will not work. We have tried.
Its an awesome product and works on almost all surfaces and some oddball stuff as well. It also does contain a cleaning agent in it and that is why we want you to rinse the area well b/c you have to wash the "soap" off.
