C6 Long Tube Headers
Lou G
A few months ago I installed a set of Mid-America Quad Cruiser mufflers.
I like the sound they make but it is too noisy in the cabin when accelerating at any speed. I am getting a little slack from the wife.
I still have the stock mufflers and thought of putting them back on but I will miss the rumble.
Anyone knows how noisy it would be in the cabin with Long Tube Headers and stock mufflers? I can probably get Kook headers for about $1,200.
The other options would be to get Corsa Touring mufflers for about $1,600.
Any thoughts would be appreciated.
Lou
I run Dynatech 1-7/8" LT's with Magnaflow complete 3" exhaust. Theres not really much a drone to me. Theres a insulator they sell to put above your torque tube and inside the cabin that will reduce sound.
Most of your sound is going to come from the mufflers, and being theres like nothing between the mufflers and the rear hatch thats were the majority of sound resonance is going to come from. Since it sounds likes to reverb off glass, itll shoot forward to the sitting cabin...
I drive around with my cutouts open ALL the time lol, only close them when a lady or someone who hates the sound gets in.
I installed a set of Melrose LT headers on my '07 and mated them to my stock exhaust/mufflers. Plenty of sound (during acceleration) without the drone or cabin noise. Slight additional power but will require a tune...otherwise you will likely throw some codes. I liked the Melrose product for the fit and finish and they come coated from the factory to reduce heat.
I removed them prior to trading the '07 because I did not want any issues w/ the factory warranty. Good luck!:thumbsup:
Thanks guys. Two good options I had not thought of.
I plan to do something within the next couple of weeks.
Will let you know what I did and how I like it.
Thanks again.
Lou
I have another question.
As I look at the different headers I see 1 7/8" and 1 3/4" dimensions. What is the difference between the two (beside size) and do you guys know what came stock with the '06?
There really is no difference its just the sz of the primary tube.
If your gonna remain stock 1 3/4" will suit what your gonna do...but if you plan on supercharging or turbos or heads and cam then the 1 7/8" would be better to accomodate the extra air your introducing into the engine.
:thumbsup:
Thank you so much.
I am thinking of heads and cam in a few months so I will go with the 1 7/8".
For a while there I thought that you and revxtreme were the same company.
Do you both do the same but are located in different parts of Florida?
Lou
Thank you so much.
Lou
No problem :)
No we're not the same company but yes basically do the same stuff.
We are in the Panhandle of FLA and they are a little ways down South. :yesnod:
Good luck with you head and cam job you will LOVE IT !!!!
Actually this is of interest to me right now. When I got my LG MotorSports Pro Long Tube headers for my C5Z, I faced that same question. From what I remember, apparently the wider primary tubes are better for high end torque, and the smaller diameter primaries are better for low to mid range torque. At least on a stock engine. Since I had in mind getting turbos (or similar power adder) later on down the road, I figured the high end torque would be well taken care of by the power adder, so I wanted the headers to help boost the low end for me.
But now that I am considering getting a 427 Warhawk motor built and dropped into the C5Z, I'm wondering if those headers are going to be an acceptable match for the larger amount of air that both the bigger motor and the increased boost that the motor will be able to withstand from the turbos. Right now the turbos are limited to only 6.5 psi, but with the new motor, then the gloves can come off and those turbos can sing as hard as they want to. I still want the low to midrange enhanced, since the turbos will still be taking care of that upper end for me, but will they then be a restriction at the upper end? Also, I'm wondering if the new heads might have exhaust ports that will be larger then the port openings in the headers.... :shrug01: Not that I would want to spend another $1,600 for new headers unless they would be a severe problem..... Maybe some experts will chip in here with some opinions....
As for the noise issue, I noted that when I had the long tube headers installed with the stock mufflers, that the tone got deeper, but particularly louder... I did some videos of a comparison a while back, so I guess they still work -> http://www.corvetteflorida.com/forums/showthread.php?t=34
But now that I am considering getting a 427 Warhawk motor built and dropped into the C5Z, I'm wondering if those headers are going to be an acceptable match for the larger amount of air that both the bigger motor and the increased boost that the motor will be able to withstand from the turbos. I still want the low to midrange enhanced, since the turbos will still be taking care of that upper end for me, but will they then be a restriction at the upper end? Also, I'm wondering if the new heads might have exhaust ports that will be larger then the port openings in the headers.... :shrug01: Not that I would want to spend another $1,600 for new headers unless they would be a severe problem..... Maybe some experts will chip in here with some opinions....
Dave at Random Technology and Chris discussed several times on doing dyno testing on this particular question and have considered with the larger displacement engines that are coming out trying a set of 2" primary headers.
Personally Rich you going with some bigger primary headers wouldnt hurt. I think even running a complete 3" exhaust system with you running that much amount of air would help.
Unless you plan on breaking 1k hp (consistently).. 1-7/8" headers and a 3" exhaust will suit you fine. Thats what Im running on the car now, and if the car needs to exhale faster thats what the cutouts are for.
Putting 2" headers on a car to make 700-800 would be like putting 1-7/8 on stock car, youll lose bottom end power.
Majority of the boosted C6Z guys on the big forums run 1-7/8. Then youve got the group of people who need the 1100+ as the low boost setting lol, who jump up bigger size headers.
I believe the LG Pro tubes have 1 3/4 primaries, if I'm not mistaken. From the collector back to the end of the input pipes for the turbos the pipes are 3 inches. Which then gets necked down to the 2 1/2 inch pipes (I think) that are standard on cat back exhaust systems on a C5. At first thought, I felt that having 3 inch plumbing all the way through the turbos would be the way to go, but the more I thought about it, the less convinced I became that this was the way to go. Turbos work on the principle of the turbine being moved by the exhaust acting on the driving vanes, which in turn moves air in a proportional fashion to the throttle body via connecting vanes that then push fresh air along. Logic would say that the more exhaust getting to the turbine and the faster the turbine spins, the more air being moved. Much like a hose nozzle on a large hose works better than the same size nozzle being on a small diameter hose, the necking down of the exhaust gases possibly HELPS provide a boost in velocity of the exhaust reaching the turbines in the turbos. Or at least it seems like this should be the case.
But turbos are weird critters to figure out. I never hear them spooling up when in first or second gear, much less sitting still just revving the engine, but if I am in higher gears (especially sixth gear) on an incline, you hear them wailing like crazy. So the amount of exhaust getting to them seems more directly related to the load on the engine, and not entirely on the rpm of the engine. I know they have to be spinning with ANY exhaust going through them, but they REALLY sing out when under some kind of load. I really think the ratings on the dynos are all rather underrated as to the amount of power that is actually getting to the rear wheels in a real world situation with turbo charged vehicles unless the drum on the dyno can put sufficient loading on the rear wheels to simulate a car weighing 3,000 pounds working against inertia to accelerate rapidly. In other words, the turbos apparently NEED something to work against that loads the engine and provides the peak power potential from them.
Heck, this all seems counterintuitive at times, but what sort of clued me in to this was when I was trying to show someone the boost gauge showing boost while just sitting still and revving up the engine. It NEVER showed any boost at all with no load on the engine. Even at 5,000 RPM, which SHOULD have been moving a lot of exhaust to the turbos, the boost gauge didn't show that the turbos were even there. Just struck me as rather odd.... Matter of fact, I thought that something was wrong and perhaps there was a break in the pipes somewhere.... But later on, out on the road, in third gear, nope, there wasn't anything at all wrong with the turbos.... Just testing the turbos, of course... :hehehe:
So, I don't know about 2 inch primaries. Sometimes you get caught up in the fallacy that if a little is good, then a LOT is better, when there always seems to be a point of diminishing returns to watch out for. But heck, maybe providing that larger piping from the exhaust ports of the heads down to being necked down right at the turbos might be worthwhile.... :shrug01: Just might be a bit too expensive getting those two inch pipes just to experiment, though...
But heck, if you guys want a guinea pig, heck, maybe I'm game.... :thumbsup: I just would want to be there to take LOTS of video.... :yesnod:
Small turbos dont need to be under heavy loads to makem sing. Look at most diesel trucks driving down the road with the 5" stack in the rear at cruising speed. Usually the turbo whine is louder then the exhaust itself.
When I had my SRT4, I had a 3" downpipe connected to the O2 housing and dumped under the cab. All you could hear was turbo, and it was only a TD-04 (at the time largest turbo on stock 4 banger turbo cars).
If your collectors on the headers are smaller then the exhaust piping itself, most would call it a bottleneck. Same principle applied to the SRT4 that if you were to put a 3" downpipe along with 3" exhaust, the "collector", or the O2 housing should also be bought or ported to 3" to maximize air flow out. Boosted cars dont love too much back pressure like a n/a car does, hence mose n/a cars not doing heads/cam stay with 1-3/4 and nothing more the 2.5-2.75" exhaust piping.
don't pay the corvette tax... obx headers 1 7/8. 650 dollars shipped special right now on corvette forum. 1200 for headers is just crazy
Well we could probably make it happen BUT the car would have to go to ATL because Random would have to make primaries especially for you car and it would need to be there , so I dont know if all that would fit in your schedule...but you just never know I'll have to look more into this...:crazy03:
Whats funny is when I google "obx corvette headers", the first link is to the corvette forum c5 tech section, and its nothing but complaints and links to other threads of horror stories.
Theyre cheap chinese ebay headers. Sure pay 600 now, but when they fault on you an you cant get a hold of their customer service, you gonna drop another 600 or so on another set?
Your money is better spent on a company who put money into R+D, engineering an the actual finished product.
I couldnt agree more there are 2 sayings we like to keep in mind around here
1----"YOU GET WHAT YOU PAY FOR"
2----"SAVE A BUCK TAKE A F*** ......well you know that word that rhymes, that a lady should never say !!
We firmly believe in this ,and while yes there are some times if you look around long enough you can find better discounts BUT you should NEVER sacrifice QUALITY while doing it !! It will always catch up to you :thumbsup:
Think there's another saying along the lines of...If you're gonna do it right, do it right the first time.
I checked their website and they don't list C6s.
I agree with the comments about buying cheap, getting cheap.
Don't want to mess with that. When I am ready, it will probably be Melrose.
