Need Help removing LT! crankshaft pulley
tblt44
1995 vette Black on Black
Ok this thing is on there.
I did all of this for a small oil leak.
I think I have a leak behind the opti or maybe from the w/p seal.I hope not the crank.My opti has oil dripping from it,it also looks soaked behind it.
I can't get the crankshaft pulley off,any suggestions from those who know how to do this.
Thanks,
Thanks,
Remove the 3 small bolts from the front side of the pulley,tap gently from the back side of the pulley above crossmember with a brass drift or short 2x4 and small hammer!! (Rt and Lt side from under the car!) After that you can remove the larger center bolt from the Pulley Hub and remove the hub if needed with a puller! (Sometimes the hub comes off easy and you may not need a puller!):thumbsup::thumbsup::thumbsup:
