Pfadt Racing header and suspension vendor
Tampa Tuning
Tampa Tuner
Here's the moment you have been waiting for so please contact us for all your Pfadt racing headers and suspension needs
The release of the new Pfadt Racing Tri-Y headers! We are truly impressed with the quality and workmanship of the headers!
As you know, Tampa Tuning has been calibrating for years. Since the release of the Pfadt Racing Tri-Y Header systems for the Camaro and Corvettes, I have consistently seen more 15-20 RWHP and RWTQ MORE on Camaro's and Corvettes that's have Pfadt units installed and we calibrate
The Pfadt Racing design takes proper exhaust flow to a new level by pairing non-adjacent cylinders together to create a super-scavenging effect with the 4-into-2-into-1 (Tri-Y) construction. In this system, the exhaust flow from individual cylinder pulses are optimized to suck air into the combustion chamber from the intake. This creates a much more efficient power curve that results in a greater amount of usable torque (called torque under the curve) in the mid-range, while not sacrificing any top-end power for peak numbers.
Pfadt - 1 7/8" x 2 1/8" x 3" Tri-Y Long Tube Headers w/Cats - 2010-2014 Camaro SS $1425 with cats Shipped
Pfadt - 1 7/8" x 2 1/8" x 3" Tri-Y Long Tube Headers w/Out Cats - 2010-2014 Camaro SS $1299 w/o cats for off road Shipped
Product Features:
C5 Corvette Headers (Tri-Y 1 3/4") C5 Headers $1,890 with HF cats shipped!
C6 Corvette Headers (Tri-Y 1 3/4") 2009+ LS3 Headers $1,890 with HF cats Shipped!
Both corvette systems are minus $250 without high flow cats for off road use
TRI-Y Design, 4-2-1 tube merging
Makes much more torque under the curve, while still increasing top end HP
1.875/2.125" tube diameter
Direct connection to factory X-Pipe and after market Cat-backs
CNC flanges with OEM locating features
Fully hand-TIG welded on-site
T-304 16 Gauge Stainless Steel
Fully Brushed Stainless Steel Finish
V-Band Clamp connections
Equal length long tubes
Available with and without Catalytic Converters
Full 3" collector
Comes with bullet-nosed flange bolts for installation
O2 Sensor extenders
Cometic Multi-Layer Steel gasket upgrade
Exhaust system with Cats is 24lbs lighter than factory
Exhaust system without Cats is 27lbs lighter than factory
Made in Salt Lake City, Utah
NO Trimming of the ZL1 belly pan!
Free Shipping to the lower 48!
The 2010-2014 Camaro SS Pfadt system was designed to bolt-on to your factory cat-back or a wide range of aftermarket systems that were designed to bolt up at the OEM connection.
Price:
$1299 w/o cats Shipped
