Bud8 said:
Does anyone know a good place to take my vette to have the rear Gears changed in jax Fl. I want to go from 2.73 to 3.73. Any info would be greatly apperciated.
Take a ride down to Sarasota. We'll get you done in a day. We have installed many gears over the years. The only gears to go with are Dynotech Engineering. I am assuming your car is a C5 in you are looking $2200 installed for a Stage 2 BUILT Gear.
DTE Stage 2 Street Performer Plus
* Standard HP upgrade package
* DTE engineered/manufactured 4340 "300M" hardened steel output shaft - left/driver side
* O.E. right output shaft
* DTE engineered, improved clutch pack oiling upgrade
* DTE engineered/manufactured heavy duty clutch pack/pre-load spring set - 34% stronger posi-traction clamping load per side
* DTE engineered pinion drive to accept the LG Motorsports Differential Cooler Kit as a bolt-on later, if chosen
Exchange or build your supplied core & includes lubricants: $1699
Turn-key installation M6/M12 and includes lubricants: $2199
Turn-key installation A4 & includes lubricants w/ custom PCM shift point calibration: $2299
Options:
* Oil cooler port, Aeroquip Fitting and oil temp probe port integrated in to main-case add: $149
* Micro-polished gear set add: $100
* DTE engineered/manufactured heavy duty 6061-T6 billet aluminum right side cover add: $649
If you would like more info call us at 941-322-0577.
