pjac5vette
Looking for advice. My ABS traction control system worked fine until my 2000 C5 sat for a month waiting on the replacement of the Heads after a failed head gasket leak.  Now the engine runs fine but the ABS traction control wont work. First I had the code C1243 and using my diagnostic computer I did the pump test and it came back with "okay". I then activated each solenoid with the computer and each time the ABS warning came up on the DIC.  This also caused the 40 amp fuse to blow whic I replace but after that the system still does not work. Today I ran codes again with my computer and got no codes for the ABS but when I start the car I get the ABS warnings in the DIC and the ABS is not on. The pump test read "okay" and I activated each solenoid and still nothing. I did the solenoid activation again with the car running and got the message on my computer, "BPMV relay is off".  Also the 40 amp fuse was blown. Evern after that I still have no diagnostic codes thrown for the ABS. Any help is appreciated.
