C5 visor removal
my drivers side visor just self destructed. completely fell apart. anyone know of a step by step removal description? thanks
From the other forum
Pull the shade down as if to block the sun.
2. Insert a flat head screw driver into the slot on the small round plastic bezel.
3. Pull the visor towards you pulling down slightly. The bar from the visor will hit the screwdriver causing the small inner bezel to rotate and pop free of the larger outside bezel.
4. Push up on the rod and turn it a little more until it is free from the healiner.
5. Disconnect the electrical connector (you may have to fish it out from inside the headliner).
