window tint removal
stormin9mm
Is there an easy procedure for this. My side windows are pretty dark, looks nice, but not fun when it is dark out. Anyone know where to buy Tint-Off?Thanks for any help.
The window tints I've had applied to my windows are nothing more then a plastic film applied to the glass. Should peel right off.
They should but remember,they're actually layered. Sometimes the top part will separate and not the bottom.
There's no real "easy" way to do it, but there is an easier way.
Amonia, heat, sharp object and patience.
Check out this link: http://www.tintcenter.com/articles/bt_removal.html
Just be careful with the razor blade so you don't cut defroster lines or scratch the window itself.
Fairly easy to do.
Gordon
I use this stuff,Cleans off the glue too!!:thumbsup:
Usually takes 1 1/2 - 2 bottles to remove a Dark Dark or Double Tinted Tint and Glue!!:thumbsup:
I get it at Advance AP in Moron NC ,Home of the Nearly Dead and Severely Inbred!!:thumbsup::thumbsup::thumbsup:
Don't get ahead of yourself,It removes 1 layer at a time!!
Do 1 window at a time,Remove Tint then remove the glue!!:thumbsup::thumbsup::thumbsup:
