Guro305
Heathen
My wipers got possessed by demons. I clean out my udders and ended up having to replace the wiper motor.
Instead of replacing just the motor because I couldn't get the dumb thing off, I ended up just swapping the whole assembly. The new assembley works great but it's got a problem and I don't know if anyone has come across this one before. The problem is it seems the wipers are misaligned. Now, I'm not talking about the wipers on the glass, I'm referring to under the cowel.
It seems that the drivers side is way higher then the passenger side. The drivers side was so high that it was beating up against my hood. I had to loosen the mount and stuck a lugnut in between the mount and the motormount to drop it down so that it's barely away from the hood. The passengers side is a different story. It's so low, that it hits the cowel (conveniently now, made itself a wider hole) and lifts up off the glass. It does come back down onto the glass and wipes on the way down.
I've been meaning to take it apart again to play around with it some more but I figured maybe someone has come across this before. Any suggestions are greatly appreciated!
