Unread 02-25-2009, 03:03 PM   #1
RelentlessNiSMo
RelentlessNiSMo's Avatar
RelentlessNiSMo has disabled reputation
Default Our STS turbo Titan project
I know this is a Corvette site but I really wanted to share with my Corvette friends. We are building a STS rear mount Turbo Titan. We will be having UpRev come in and tune the truck when we get done with the build. I will be posting up pics from beginning to end, and keep everyone updated on the progress. We have the truck and are now doing the pre modifications needed before the actual mock up begins. Here is some info on STS systems for those that are not familiar with it.
Benefits of STS Remote-Mounted Turbochargers
# Lower underhood temperatures. No need to worry about melting wires, hoses, or other engine components, as with a front-mounted turbo.
# Ease of installation. STS turbo systems can be installed in about 8 hours with standard tools and average mechanical ability.
# Cooler oil to the turbo. Cool oil is better for both the turbo and engine.
# Performance Sound. The turbo acts as a muffler and sounds like an aftermarket performance muffler. Turbo spool and rushing air from the blow-off valve make a unique sound that will turn heads!
# No need for major modifications to your vehicle. STS systems are designed to "bolt-on" to factory mounts.
# Increased gas mileage. Unlike a belt driven supercharger, the turbo utilizes "wasted" energy leaving your tailpipe. Most of our customers get 1-3 mpg increase in gas mileage compared to their original stock mpg numbers.
# Converts back to stock in about an hour.
# More room under the hood. Future repair work or modifications will not require the expense of removing the turbo system to allow access to engine components.
# Lowest Intake Air Temps. Low IAT's equate to more horsepower per pound of boost than any other forced induction option. STS intake piping provides built-in intercooling. Add the optional intercooler, and IAT's drop even further.
# Approximately 500F lower turbo temperatures. Eliminates the need for a turbo-timer, which allows the engine to run after the car is shut off in order to cool down the turbo and prevent oil and bearing damage.
# Denser exhaust gasses drive the turbo turbine wheel more efficiently.
# Turbo is exposed to ambient air rather than underhood air. Allows for better cooling of turbo components.
# No need for expensive headers, mufflers, or exhaust systems.
# Turbo is closer to the tail pipe outlet. Provides a better pressure differential across the turbine wheel which promotes better flow across turbine.
# Better weight transfer. Increases traction because the bulk of system is mounted in rear of vehicle rather than up front.
# Less noise and heat in the passenger compartment.
Gutted for the interior mods
Bone stock Titan
Lowered with new wheels on it. 22"s
Alligator interior
RelentlessNiSMo is offline   Reply With Quote
Project Split Personality AC and Audio Install - The Finale RSS Feed Tech and How-To Articles 0 02-23-2009 03:00 PM
Project C5X Baer Brake Rotor Install - Braking News RSS Feed Tech and How-To Articles 0 01-06-2009 06:00 PM
FS:1981 Turbo Trans Am,True NASCAR Recaro Pace Car! Great Condition! Only 1 of 2000 ! antneed Flea Market 2 07-07-2008 08:26 PM
STS Turbo Systems. john.stankosky Classifieds - Corvettes, Parts & Accessories 3 03-06-2007 12:21 PM
STS twin turbos - status on 12/11/06 Rich Z Maintenance, Mods, & Tips 31 01-28-2007 10:30 AM
Page generated in 0.31156111 seconds with 10 queries
