Competitions and Racing Forum Any and all forms of contests. "Kill" stories are OK, but please note that this site does NOT condone illegal activities. So discretion is advised. |
07-23-2012, 02:07 PM
XP MOTORSPORTS
Name : XP Motorsports
Brake Cooling Parts
Brake Cooling Parts
Keep your brake rotors and calipers cool with our brake cooling parts. We have many options available for you.
3" Compact Inline Blower, 5" Long, 140 CFM
Works great install inline in the stock front splitter opening
$28.99
Durable plastic brake ducts direct outside air for cooling brakes, oil coolers ... even the driver, and are available in centered, offset and dual outlet configurations.
Dim 5.5" x 8"
This fits perfectly behind the font grille no cutting of the grille some modification to the inner grille required for mounting
$18.99
http://www.xplosiveperformance.com/B...nt_p_3054.html
Brake Duct - Offset Single
Dim 5" x 9.75"
Works great if you want to remove the fog lights fits with minor modification
$21.99
http://www.xplosiveperformance.com/B...le_p_3055.html
Brake Duct Hose, 3" x 10', Orange, 550 degrees
Hose is designed to direct air from front mounted air ducts to spindle ducts for brake cooling. Flexible, non kinking hose is available in three temperature ranges. Sold in 10 ft. lengths. 275 degree - 3" single ply thermoplastic rubber wall with a spring steel wire support. 300 degree - 3" or 4" double ply neoprene coated woven fiberglass hose with a spring steel wire inner and an external fiberglass cord support. Smooth inner wall for unrestricted flow. 550 degree - 3" or 4" double ply silicon coated woven fiberglass hose with a spring steel wire inner and an external fiberglass cord support. Smooth inner wall for unrestricted flow.
3" Brake Duct Hose Flange
Flange rivets to nosepiece. 3" diameter brake duct hose can then be hose clamped to flange.
$28.99
07-23-2012, 03:28 PM
Sinister C4
Any spindle ducts, especially for 88-96? I've added that to the list of goodies for my vette by years end!
07-28-2012, 09:18 AM
XP MOTORSPORTS
We have not had a big demand for the 88-96 years i am sure we can come up with something for you. Keep me posted we'll work with you.
