Unread 11-30-2007, 01:15 PM   #1
Pres712
Pres712
Pres712's Avatar
Name : Jim Hildebrand
Pres712 is on a distinguished road
Thumbs up Clutch fluid
I was on the "other" forum the other day and read about changing the clutch fluid? I had heard rumors about our 6-speed C-5's having "clutch fluid" but didn't give it much thought. Y'all got to remember I started driving in the 50's and a clutch had a big fork and spring, throwout bearing and that was it. But fluid? Well, I went out and bought a new can of Prestone DOT-4 (recommended) and went thru the steps. When I pulled off the cap, uggh, what a oily mess! After only two purges it was clean. Didn't take more than 20 minutes and half of that was making sure all surfaces were covered! So if you have a six-speed get ur done!!!
Pres712 is offline   Reply With Quote
Unread 11-30-2007, 01:45 PM   #2
JIM KILL
TampaBay Vettes
JIM KILL's Avatar
JIM KILL is on a distinguished road
Talking Thanks Pres
Just got the "Zee" and I guess "Andre" has a project this week-end at Insty-Tune. My last 3 Vettes were Automatics....My First 6 speed.
"Thanks for the Heads Up"
JIM
Get in, Shut up and Hold on!!!
JIM KILL is offline   Reply With Quote
Unread 11-30-2007, 02:00 PM   #3
Pres712
Pres712
Pres712's Avatar
Exclamation Easy
Hey Jim: Like I said, it's really easy. By the way it's DOT-3 not 4. Four has a higher boiling point and if you go to it you should bleed the entire system. So go to Wal-Mart and for about $3.00 get Prestone DOT-3. Cover the entire area (brake fluid eats paint) and take off the cap. The rubber insert will probably stay in the reservoir; so very carefully take it out, wipe it off and get a syringe and suck out the fluid. There isn't very much in there and when you hit bottom use a lintless towell to wipe it out. About 3/4 of the way to the top is a line; that is where you fill it with the new fluid. Put it back together and pump the clutch about 20 times. Look in the reservoir and if it isn't as clean as the new fluid, do it again. I only had to do it twice and it was clean and pure. That's it! Like I said it took more time to cover the area than to do the job. Have fun....
Unread 11-30-2007, 02:54 PM   #4
Yeah, this is well worth doing, especially if you run your car hard.... Here's a thread started earlier about this process.... -> http://www.corvetteflorida.com/forum...ead.php?t=2733
Club Fluid Site Of Deadly Shooting RSS Feed Florida News Feeds 0 10-17-2007 07:43 PM
Transmission fluid Cathies627 Maintenance, Mods, & Tips 2 08-21-2007 07:16 AM
Clutch install labor cost, wtf?!?!? Gannet Maintenance, Mods, & Tips 2 12-21-2006 06:07 PM
Clutch smell Mark Dalton Maintenance, Mods, & Tips 1 07-12-2006 09:14 PM
Brake Fluid Question Charlie882 Maintenance, Mods, & Tips 6 06-23-2006 01:56 AM
Page generated in 0.12531495 seconds with 10 queries
