Unread 01-22-2008, 01:15 PM   #1
Vettever
Vettever has disabled reputation
Default 02 Z06 starting problem
Every once in a while I turn the key and nothing, like the baa=ttery is dead or the clutch isn't on the floor. The battery is new and after several tries it starts. Yesterday it took me aboth 20 tries before it went. It's a daily driver with 19000 miles. I don't want to give it to the dealer because I'm afraid they will tie it up for a week, charge me a fourtune and not find anything wrong. Anybody got any hints?
Thanks
Joe
Vettever is offline   Reply With Quote
Unread 01-22-2008, 01:32 PM   #2
marineman1
marineman1 has disabled reputation
Default no start
could be a bad key (chip) try the other key
marineman1 is offline   Reply With Quote
Unread 01-22-2008, 02:00 PM   #3
Vettever
Thanks alot, it's a great suggestion! I'll swap keys now, but it will take a while to know if this it it because it could be a couple months before it would happen. Crazy but sooner or later it will let me down. Thank you again!
Joe
Unread 01-22-2008, 03:01 PM   #4
fletcher4u
fletcher4u has disabled reputation
It may also need the battery end and bolts cleaned or a cable is not tight
fletcher4u is offline   Reply With Quote
Unread 01-22-2008, 03:18 PM   #5
gmjunkie
Corvette,GM Classic Freak
gmjunkie's Avatar
Name : I'm Not Post'n in BOI
gmjunkie is on a distinguished road
Joe
Take some denatured alcohol and clean the switch contacts on each side just inside the opening with a cotton swab.Be careful not to lose the end of the swab in it!! It just takes a little lint from your pocket or oil from your hands to make them not get a good connection!! Clean your Key too!!
junk!!
gmjunkie is offline   Reply With Quote
Unread 01-22-2008, 06:59 PM   #6
98 softtail
Bug Killer
98 softtail's Avatar
98 softtail will become famous soon enough98 softtail will become famous soon enough
There used to be a spray alcohol that you could get at computer stores, if it is still available that might work.
Joe B.
98 softtail is offline   Reply With Quote
Unread 01-22-2008, 09:05 PM   #7
JCswm
JCswm's Avatar
JCswm is on a distinguished road
you need to go to or call the dealership once in a while Just to check for recalls
The GM electrical Contact Cleaner is the best I've ever used Along with Their fuel Injecter Cleaner.... Hell the GM hand cleaner is pretty damn good stuff too!!!
1973 RED L-82 4-speed Convertible Daily Driver!!
Modified (by me)Vortec 350 engine
JCswm is offline   Reply With Quote
Unread 01-22-2008, 09:46 PM   #8
I had this identical problem. Every once in a while I would turn the ignition key and .... nothing..... Gradually got worse. The culprit was a loose or corroded battery connection on the starter itself. One of the service writer techs could actually see sparking when he was looking under the hood.
If it is the battery connection itself AT the battery, I would expect your clock to get reset every time you had this problem, since you are dropping electricity to the entire car.
Unread 01-22-2008, 09:55 PM   #9
JCswm
JCswm's Avatar
Something as simple as your phone plugged into the cig lighter can retain enough power in the system to keep your ign off power high enough to retain system memory!!!
Corvette Z06 Chosen to Pace 50th Daytona 500 in 2008 RSS Feed Corvette News Feeds 0 11-19-2007 02:16 PM
C5 Corvette Z06 Body And Exterior Makeover - Extreme Makeover C5 Edition RSS Feed Tech and How-To Articles 0 10-04-2007 01:05 AM
C5Z vs. C6Z Zach Z06Fever! 4 05-14-2006 08:27 PM
Page generated in 0.08602691 seconds with 10 queries
