Unread 05-13-2008, 08:47 AM   #1
C3/C5-PAT
C3/C5-PAT has disabled reputation
Default My first question..........
Guys,
This is my first question for the group since joining a few weeks ago.
I have owned an 04 Z06 for about 6 weeks and twice when I've started the car in the morning, I get a "charging system failure" message. The car starts and runs just fine. Do I have a weak battery?
Pat
C3/C5-PAT is offline   Reply With Quote
Unread 05-13-2008, 09:45 AM   #2
JIM KILL
TampaBay Vettes
JIM KILL's Avatar
JIM KILL is on a distinguished road
Talking Battery
Battery is one item to check.
It could be the charging system itself. The alternator could be going bad, or not keeping the battery fully charged. Also it could be a bad ground from the battery. Are both positive and negative connections on the battery nice and tight? I would check the voltage at the alternator and then at the battery. you will have a small voltage drop at the battery but not much. Example would be 14.2 at the alternator and 13. 8 or so at the battery. Take it to an Electrical Shop or Dealership.
JIM
Get in, Shut up and Hold on!!!
JIM KILL is offline   Reply With Quote
Unread 05-13-2008, 09:50 AM   #3
C3/C5-PAT
Thanks Jim......all goods ideas....I will go thru your list today after work.
Pat
Unread 05-13-2008, 05:52 PM   #4
I had a similar error code a while back. Turned out to be a corroded/loose connection going to the starter......
Unread 08-12-2008, 10:20 AM   #5
dvdcta
dvdcta has disabled reputation
Default question
JIM
I have trashed two altenators this year & two batts really hard on parts over rev I do that
dvdcta is offline   Reply With Quote
Unread 08-13-2008, 05:20 AM   #6
davekp
davekp has disabled reputation
Loose connection at the starter is a known C-5 issue. Check it.
davekp is offline   Reply With Quote
Unread 08-13-2008, 05:39 AM   #7
dvdcta
Default question
got a c-4 I know what the problem is its the one behind the steering wheel!! can't keep foot out !!! I have ground straps all over this baby because I run nitrous!!
Unread 08-13-2008, 07:11 AM   #8
Shadow
Shadow's Avatar
Shadow will become famous soon enough
Enough of the ramblings. Please remain on topic.
Shadow is offline   Reply With Quote
Bathroom Flood... Question???? ynkedad The Ranting Room 29 08-11-2008 08:07 PM
HPTuners question about "delivered torque". Rich Z Performance Tuning 9 08-10-2008 02:47 PM
C4 Question presicion25 General Corvette Discussions 6 07-19-2008 01:27 PM
Maybe a Dumb Question? JIM KILL Maintenance, Mods, & Tips 20 10-04-2007 11:15 PM
Question on Lowering TR6speed Maintenance, Mods, & Tips 2 12-05-2006 12:39 PM
Page generated in 0.13931894 seconds with 10 queries
