Unread 10-11-2007, 06:23 PM   #1
RevXtreme 1
www.revxtreme.com
RevXtreme 1's Avatar
RevXtreme 1 has disabled reputation
Default Built Rear carriers in stock, most ratios!
C5 built rear gears in most ratios from 3.42-4.10. All are built to DTE Stage II & III spec with in stock motive gears for your carrier. Call for prices & install/tune specials. 813-628-0080
We can do the swap while you wait for most with your carrier in trade as a core.
Tech Support for most anything.
RevXtreme 1 is offline   Reply With Quote
Unread 10-12-2007, 08:34 PM   #2
RevXtreme 1
www.revxtreme.com
Free install/swap or $250 Dyno tune.
3.42, 3.90 & 4.10's ready to ship or install.
Unread 10-13-2007, 08:28 AM   #3
chris308
spam sniper
chris308's Avatar
chris308 is on a distinguished road
What gears are in a 99 vert mn6?
chris308 is offline   Reply With Quote
Unread 10-13-2007, 08:47 AM   #4
RevXtreme 1
www.revxtreme.com
You should have 3.42's in it stock.
Unread 10-16-2007, 07:43 PM   #5
chris308
spam sniper
chris308's Avatar
Tracy,
Whats are the pro's and con's of going with the 3.90's or 4.10's?
How will either on work with future mods?
Unread 10-16-2007, 08:23 PM   #6
RevXtreme 1
www.revxtreme.com
Originally Posted by chris308 View Post
Tracy,
Not many cons with the 3.90's w/MN6 cars, unless you are targeting 700-800 rwhp or more. (we put 3.42's in the 1,000 RWHP Z06 we built for top speed capabilities) The final ratio of the MN6 (both 5th & 6th are overdrive) makes the 3.90 wild for acceleration & still reasonable fuel economy at freeway speeds. The 4.10's would be more for a track car that wants to be in the peak power band through most gears, but will be a little high on RPM at 75-80 cruise & fuel economy will suffer a bit more than the 3.90's.
With either, dead stop acceleration will be a traction issue, but practice & the right tires will help. Remember, the stock clutch is only good for only so much abuse.
Unread 10-16-2007, 09:59 PM   #7
With 4.10s, you really don't even need first and second gear in normal driving....
Page generated in 0.06452489 seconds with 10 queries
