1987 no start help
arajeana
We are trying to solve a 1987 corvette no start problem . Will try to start then nothing :banghead:.... we have replaced EVERYTHING !!!! Need info about what makes the car go from bypass to tsc . Will it even try to start if vats is tripped ? Have tried bypass , new module etc new ecm etc . Need a good troubleshooting guide or a tech manual .... :shrug01: help:shrug01: Thanks !!!! :wavey:
There is a C4 expert going to Florida soon "GM Junkie.He's a member and has a place in Vero Beach.I'd contact him .Tried to locate Batesville but couldn't find it on map quest.
Have you checked to see if you're getting fire to the plugs? And as for the VATS, no. If the VATS is tripped you will get nothing. Will try to start then nothing....sounds like a fuel or MAF issue to me.
