i did that last night after dark. no lights. so heres where im at. havent had any electrical problems in well over a year. got optima red top battery that holds a charge and solid voltage. took the dash out. had to drive to work in car with no dash. just plugged the cluste back in. last week thurs. i wired in the heads up dislpay. drove to work friday. cluster and hud working. running around all weekend and didnt have time to touch it. monday morning, battery completely dead. put charger on, and got buzzing sound from bcm. removed the battery and trickle charged overnight. checked voltage in mornig and voltage good. after work checked voltage and all good. reinstalled battery and no probelm. no buzzing, car starts right up. left over night, and in morning, low voltage warning, and starter clicking. got home after work and battery complely dead. disconnected the battery and am searching frantically to figure out whats going on. one idea i had was that somehow a few days after dash removal, a wire connected and grounded out the hvac fan. the fan is activated when grounded (for some reason that still alludes me) but i removed the plastic cover over the hvac fan, and nothing. when the battery was full the fan was off. i turned it on and went from lowest to highest setting, then shut off again. so its not the hvac fan grounding out. the new things in installed worked fine for several days with no problem. i have found no water around the bcm, or evidence of moisture. im lost and getting to the point of dropping off at at shop. ive tried to get ahold of greg at antivvenom a few times, but have had no luck. may have to go to corvette shop or some place out in st. pete that workd on vettes. i ussually can fix my car thru the use of forums, the shop manual, or experience, but im have no clue on this one.
