mickeystoysz16
I have stripes
With the regular wt 5-30 I am getting 44 psi at startup with 40-43 psi @normal operating temperature in a stock C5Z.
I put in a Fumoto oil change valve to replace the regular oil pan drain plug while I was at it. Had to fiddle around with extra gaskets to make it sit at the correct angle, though, and not have the valve handle hanging down exposed to road debris while driving.
Rich, got any pictures of the installed valve? Which model did you use, and
are you using an extension? That sounds like something that would be worthwhile
doing on my engine, and I would like to know EXACTLY what to order to do
it correctly the first time.....! Don't need no stinkin visit from Mr. Murphy!
Andy :wavey:
Rich, Thanks for the pix! Yep! You're probably right to install a zip-tie on that
sucker! Been reading this thread too long, not to get the idea that if it weren't
for bad luck, you would have no luck at all. You must have used up all of your
good luck when you married Connie!I went to the web site of the manufacturer
and saw a cutaway model of the valve, and it's a ball valve which to my mind is the only type of valve to use on anything liquid. Do you have anything negative
to say about the valve so far like workmanship, hard to open or close, dripping,
etc..? This might be one of those "looks too good to be true" deals, but then it
might just be a quality product that does what it's designed to do. If that's the
case, I'll have to order one for my car.
Andy :thumbsup::thumbsup::wavey:
Thanks Rich! Good info.:thumbsup: I change the oil in the garage with the Vette
up on ramps, and it's not that high. There's ALWAYS a mess! I put down the
cheap shower curtain liners that you can get for a buck at dollar general to
protect the floor, but that valve would cut down on some of the mess as well as
saving the threads by not having to remove the plug everytime.
Andy :wavey:
With the thin oils, after a test drive my oil pressure would be hovering around 22 to 24 psi when idling in front of the garage door. This is OK, according to the experts, but I want to see what this thicker oil will do for the pressure.
Were do you get that oil. My 122K 93 only has 15# idle and 30 hot at road speed. It might be interesting the next oil change to see if it would improve my old engine oil pressure.
